Yocto: Can not download FSL Community BSP (krogoth)
petertseng
Hi i.MX Community,
I am trying to download the FSL Community BSP (krogoth) source code.
mkdir ~/bin
curl http://commondatastorage.googleapis.com/git-repo-downloads/repo > ~/bin/repo
chmod a+x ~/bin/repo
PATH=${PATH}:~/bin
mkdir fsl-community-bsp
cd fsl-community-bsp
repo init -u https://github.com/Freescale/fsl-community-bsp-platform -b krogoth
repo sync
But has been unable to download complete.
Hope for your help!
Labels (3)
gusarambula
Hello Peter Tseng,
The steps look okay. Are you not having a sources folder and a setup-environment script inside fsl-community-bsp after the sync? This could be caused if you do not have a good internet connection or if you are under a proxy or firewall, please check your network settings  and internet accessibility.
aravinthkumarja
Senior Contributor II
Hi Peter,
Follow the freescale user guide.
Aravinth
