Unable to load key to SECO
98 次查看
Chandni
Hi All,
On IMx8DX, I am trying to generate a key blob using SECO and then I want to load the key to SECO using this key blob. For this I am using these two APIs: sc_seco_gen_key_blob() and sc_seco_load_key().
My chip is in OEM closed lifecycle state.
I have two questions:
  1. I can generate KEY blob using sc_seco_gen_key_blob() but only a DEK key blob. I could not generate any other key blob like KEK, I always get  SECO Event[1] = 0x00AFBC2. Is it not possible to generate any key blob other than DEK key blob?
  2. Once I generate the DEK key blob, I want to load the key to SECO. For this I am using sc_seco_load_key(). It always fails with the SECO Event[1] = 0x0090A429. I cannot understand why It fails. I know that 0xA4 is AHAB_BAD_BLOB_IND but I passed the same the key blob which was generated earlier with the same key Identifier to sc_seco_load_key(). Can you please throw some light on it?
@Yuri
Thanking you in advance.
Chandni
标记 (3)
59 次查看
Harvey021
Can generate these blobs
The API load key is for IEE
For storing common data, you can consider using CAAM red/black blob directly
Harvey
