UUU issues on IMX6SX
mabar52
Trying to build write and boot u-boot with uuu utility.
Our board is based on the sabresd reference with IMX6SX and qspi-flash.
SO-AP-SE-19:uuu root# ./uuu -lsusb
uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.5.125-5-g1a9d927
Connected Known USB Devices
Path Chip Pro Vid Pid BcdVersion
2:11 MX6SX SDP: 0x15A2 0x0071 0x0001
SO-AP-SE-19:uuu root# ./uuu -s
Build in config:
Pctl Chip Vid Pid BcdVersion
SDPS: MX8QXP 0x1fc9 0x012f [0x0002..0xffff]
SDPS: MX8QM 0x1fc9 0x0129 [0x0002..0xffff]
SDPS: MX8DXL 0x1fc9 0x0147
SDPS: MX28 0x15a2 0x004f
SDPS: MX815 0x1fc9 0x013e
SDPS: MX865 0x1fc9 0x0146
SDPS: MX8ULP 0x1fc9 0x014a
SDPS: MX8ULP 0x1fc9 0x014b
SDPS: MX93 0x1fc9 0x014e
SDP: MX7D 0x15a2 0x0076
SDP: MX6Q 0x15a2 0x0054
SDP: MX6D 0x15a2 0x0061
SDP: MX6SL 0x15a2 0x0063
SDP: MX6SX 0x15a2 0x0071
SDP: MX6UL 0x15a2 0x007d
SDP: MX6ULL 0x15a2 0x0080
SDP: MX6SLL 0x1fc9 0x0128
SDP: MX7ULP 0x1fc9 0x0126
SDP: MXRT106X 0x1fc9 0x0135
SDP: MX8MM 0x1fc9 0x0134
SDP: MX8MQ 0x1fc9 0x012b
SDPU: SPL 0x0525 0xb4a4 [0x0000..0x04ff]
SDPV: SPL1 0x0525 0xb4a4 [0x0500..0x9998]
SDPV: SPL1 0x1fc9 0x0151 [0x0500..0x9998]
SDPU: SPL 0x0525 0xb4a4 [0x9999..0x9999]
SDPU: SPL 0x3016 0x1001 [0x0000..0x04ff]
SDPV: SPL1 0x3016 0x1001 [0x0500..0x9998]
FBK: 0x066f 0x9afe
FBK: 0x066f 0x9bff
FBK: 0x1fc9 0x0153
FB: 0x0525 0xa4a5
FB: 0x18d1 0x0d02
FB: 0x3016 0x0001
FB: 0x1fc9 0x0152
FB: 0x0483 0x0afb
Please input command:
U>SDP: dcd -f files/u-boot-smartoptics-dcp.imx-memtest
>Start Cmd:SDP: dcd -f files/u-boot-smartoptics-dcp.imx-memtest
New USB Device Attached at 2:11
100%2:11>Okay (0.009s)
Okay
U>SDP: write -f files/u-boot-smartoptics-dcp.imx-memtest
2:11>Start Cmd:SDP: write -f files/u-boot-smartoptics-dcp.imx-memtest
0%2:11>Fail HID(W):LIBUSB_ERROR_IO(0.004s)
Is there a way to further debug this to know why the error occurs.
With another build u-boot configutation:
SDP: dcd -f files/u-boot-memtest-DCP-R8.0-r0.imx
SDP: write -f files/u-boot-memtest-DCP-R8.0-r0.imx -ivt 0
SDP: jump -f files/u-boot-memtest-DCP-R8.0-r0.imx -ivt 0
(reverse-i-search)`-s': cat dcp-start-u-boot.lst.memtest
Build in config:
        FBK:                     0x066f  0x9afe
        FBK:                     0x066f  0x9bff
        FBK:                     0x1fc9  0x0153
        FB:                      0x0525  0xa4a5
        FB:                      0x18d1  0x0d02
        FB:                      0x3016  0x0001
        FB:                      0x1fc9  0x0152
        FB:                      0x0483  0x0afb
U>SDP: dcd -f files/u-boot-memtest-DCP-R8.0-r0.imx
>Start Cmd:SDP: dcd -f files/u-boot-memtest-DCP-R8.0-r0.imx
2:11>Okay (0.004s)
Okay
U>SDP: write -f files/u-boot-memtest-DCP-R8.0-r0.imx -ivt 0
2:11>Start Cmd:SDP: write -f files/u-boot-memtest-DCP-R8.0-r0.imx -ivt 0
2:11>Fail HID(W):LIBUSB_ERROR_TIMEOUT(2.157s)
We use several u-boot compilations that serve different purposes and we have recently upgrade our yocto environment from 2.7 to 4. We have several patches and separate defconfigs that are applied depending on what kind of u-boot configuration that is built.
I suspect that I miss some kCONFIG to u-boot, not sure how to check that, though.
This is an old build that works and I can see through the console that u-boot is started:
U>SDP: dcd -f files/u-boot-qspi2-DCP-R7.0-r0.imx
>Start Cmd:SDP: dcd -f files/u-boot-qspi2-DCP-R7.0-r0.imx
100%2:11>Okay (0.008s)
Okay
U>SDP: write -f files/u-boot-qspi2-DCP-R7.0-r0.imx -ivt 0
2:11>Start Cmd:SDP: write -f files/u-boot-qspi2-DCP-R7.0-r0.imx -ivt 0
100%2:11>Okay (0.178s)
Okay
U>SDP: jump -f files/u-boot-qspi2-DCP-R7.0-r0.imx -ivt 0
2:11>Start Cmd:SDP: jump -f files/u-boot-qspi2-DCP-R7.0-r0.imx -ivt 0
100%2:11>Okay (7.03s)
Okay
U>
Any help is most welcome, of course.
