The side effect/impact of SSC(Spectrum Spread) on PLL2.
1,045 次查看
asou_junichi
SSC(Spectrum Spread) is enabled and only DDR and LVDS use the PLL2 clock.
(PLL2 clock : 396MHz -> 384MHz by 23kHz step)
In the case, are there any side effect/impact to the connected devices to the clock delivered from PLL2?
857 次查看
yes one should consider SSC effect on any devices (modules) using that clock,
in particular for ddr check micron document p.14
http://www.micron.com/~/media/documents/products/data-sheet/dram/ddr3/ddr3l_2gb_graphics_addendum.pd...
857 次查看
asou_junichi
Thank you for an answer.
I got it.
BR,
Jun
858 次查看
