PCIE link failed on MIMX8MQ6CVAJZAA
Eddy1
Hi:
Recently, I found that my development board always fails to detect the SSD in the PCIe1 slot after a period of use. What could be causing this issue? Currently, I am using BSP 4.19.35(yocto Warrior). It worked fine after replacing the CPU.Can you provide some suggestions?
