I am trying to implement wake up Linux from sleep mode. To enter sleep I use 'echo mem > /sys/power/state' command. To wake up I would like to use GPIO interrupt on IOMUXC_UART1_RXD_GPIO5_IO22 pin. I use example from:
For that purpose I create overlay for gpio5, like below:
&gpio5 {
status = "okay";
pad-wakeup-num = <1>;
pad-wakeup = <pad_id SC_PAD_WAKEUP_HIGH_LVL 22>;
But I can't find what mean pad_id ? Where I should looking for pad_id ? Is working this solution for IMX8MM ?
Solved! Go to Solution.
the link you sent is for imx8qm, you can refer to the topic as below which has the similar topic
Thanks, solution what you shared, works fine
