Layout Design Guide Line for LPDDR4 on i.MX8QX
4,014 次查看
tanno_yoshihiro
Now, we are designing our evaluation board circuit using iMX8QX.
So we want to know the following specification for LPDDR4 Layout Design Guide Line.
1.Line Length Difference (Differential Pair P/N, CK/DQS)
2.Line Length Difference (Single - ended, CS/CKE/DMI/CA/DQ)
3.Space between Differential Pair and Other Traces
   - CK_t/c to CAx, CS_n
   - CK_t/c to CKEx
   - CK_t/c to DQSx_t/c
   - DQS_t/c to DQ
   - DMI to DQ
4.Characteristic Impedance (Z0)
5.Differential Impedance (Z0_diff)
Thanks a lot
Yoshihiro
6 回复数
2,080 次查看
Okiann
Hi Yuri,
May I have a copy of the guide doc in pdf? Could you send me through email if it is available to send. Thank you.
3,138 次查看
Yuri
   I've sent You reply directly.
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
3,104 次查看
tiagoborth
Hi Yuri, it would be possible share the same information regarding iMX8QX + LPDDR4 line impedances?
3,087 次查看
Yuri
1,517 次查看
hrudaynath
Hi Yuri
can you please send this document to me please
hrudaynath.chaudhari@cummins.com
标记 (1)
3,137 次查看
sergeyserg
Hello Yuri,
Now I am doing pcb design with iMX8MMini and I have got the same questions about layout LPDDR4 only for iMX8MMini. Could you send me these layout applications LPDDR4 for iMX8MMini?
Serg.
