LVDS panel (side by side)screen problem (Imx6-sabresd)
1,853 次查看
sonsungho
I use Left / Right type dual port Lvds   (not Odd/Even)
Channel 1 and Channel 2 display the same screen
What's the problem?
Imx6-sabresd / android 6.0.1 // kernel 4.1.15  //Panel is LA123WF1
imx6qdl-sabresd.dtsi
mxcfb1: fb@0 {
compatible = "fsl,mxc_sdc_fb";
disp_dev = "ldb";
interface_pix_fmt = "BGR24";
default_bpp = <32>;
int_clk = <0>;
late_init = <0>;
status = "okay";
&ldb {
status = "okay";
split-mode;
lvds-channel@0 {
fsl,data-mapping = "spwg";
fsl,data-width = <24>;
primary;
status = "okay";
display-timings {
native-mode = <&timing0>;
timing0: hsd100pxn1 {
clock-frequency = <89400000>;
hactive = <1920>;
vactive = <720>;
hback-porch = <16>;
hfront-porch = <16>;
vback-porch = <3>;
vfront-porch = <3>;
hsync-len = <32>;
vsync-len = <2>;
What am I to do?
Thanks for your response.
标记 (3)
1,314 次查看
weidong_sun
Hello SON,
     Attachment is a patch for dual-lvds application in dts, you can modify resolution and other parameters according to your LCD datasheet.
Weidong
