LTIB Build Error - imx-lib
4,220件の閲覧回数
abdulrazak
Hi All,
I am running in to a issue while building ltib for i.mx35. Please help me solve this issue.
Also has some one built gstreamer package for i.mx35. If yes, please let me know the steps.
Below is the log.
Processing: imx-lib
Build path taken because: directory build, build key set, no prebuilt rpm,
rpmbuild --dbpath /home/dt-blr-04440/ltib/rootfs//var/lib/rpm --target arm --define '_unpackaged_files_terminate_build 0' --define '_target_cpu arm' --define '__strip strip' --define '_topdir /home/dt-blr-04440/ltib/rpm' --define '_prefix /usr' --define '_tmppath /home/dt-blr-04440/ltib/tmp' --define '_rpmdir /home/dt-blr-04440/ltib/rpm/RPMS'  --define '_mandir /usr/share/man' --define '_sysconfdir /etc' --define '_localstatedir /var' -bi --short-circuit  /home/dt-blr-04440/ltib/dist/lfs-5.1/mxc-misc/imx-lib.spec
Building target platforms: arm
Building for target arm
Executing(%install): /bin/sh -e /home/dt-blr-04440/ltib/tmp/rpm-tmp.17553
+ umask 022
+ cd /home/dt-blr-04440/ltib/rpm/BUILD
+ cd imx-lib-10.04.01
+ [ -z  ]
+ KERNELDIR=/home/dt-blr-04440/ltib/rpm/BUILD/imx-lib-10.04.01/../linux
+ KBUILD_OUTPUT=/home/dt-blr-04440/ltib/rpm/BUILD/imx-lib-10.04.01/../linux
+ rm -rf /home/dt-blr-04440/ltib/tmp/imx-lib
+ [ -n  ]
+ echo imx35_3stack
+ awk {print toupper($0)}
+ PLATFORM_UPPER=IMX35_3STACK
+ make PLATFORM=IMX35_3STACK DEST_DIR=/home/dt-blr-04440/ltib/tmp/imx-lib//opt/freescale/rootfs/arm install
make -C ipu install
make -C screenlayer install
make[1]: Entering directory `/home/dt-blr-04440/ltib/rpm/BUILD/imx-lib-10.04.01/ipu'
make -C sim install
Not support platform, will not complile
make[1]: Leaving directory `/home/dt-blr-04440/ltib/rpm/BUILD/imx-lib-10.04.01/ipu'
make -C vpu install
make[1]: Entering directory `/home/dt-blr-04440/ltib/rpm/BUILD/imx-lib-10.04.01/screenlayer'
make[1]: Entering directory `/home/dt-blr-04440/ltib/rpm/BUILD/imx-lib-10.04.01/sim'
make[1]: Nothing to be done for `install'.
make[1]: Leaving directory `/home/dt-blr-04440/ltib/rpm/BUILD/imx-lib-10.04.01/sim'
make[1]: Leaving directory `/home/dt-blr-04440/ltib/rpm/BUILD/imx-lib-10.04.01/screenlayer'
make[1]: Entering directory `/home/dt-blr-04440/ltib/rpm/BUILD/imx-lib-10.04.01/vpu'
make[1]: Leaving directory `/home/dt-blr-04440/ltib/rpm/BUILD/imx-lib-10.04.01/vpu'
+ exit 0
Processing files: imx-lib-10.04.01-1
error: File not found by glob: /home/dt-blr-04440/ltib/tmp/imx-lib/opt/freescale/rootfs/arm/*
RPM build errors:
Build time for imx-lib: 0 seconds
Failed building imx-lib
f_buildrpms() returned an error, exiting
traceback:
main:560
Started: Wed Dec  5 09:20:10 2012
Ended:   Wed Dec  5 09:26:32 2012
Elapsed: 382 seconds
These packages failed to build:
imx-lib
Build Failed
ラベル(3)
2 返答(返信)
2,686件の閲覧回数
brunoceldran
I have a similar problem while compiling imx-libs-1.1.0 for my iMX6 platform, with ptxdist.  It won't help you at all, but maybe it can guide to the resolution of the problem.
target: imx-lib.compile
make[1]: Entering directory `/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/imx-lib-1.1.0'
make -C sim all
make -C vpu all
make -C pxp all
make -C rng all
make[2]: Entering directory `/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/imx-lib-1.1.0/sim'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/imx-lib-1.1.0/sim'
make -C ipu all
make -C sahara2 all
make[2]: Entering directory `/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/imx-lib-1.1.0/vpu'
arm-cortexa9-linux-gnueabihf-gcc -DIMX6Q -Wall -O2 -fPIC -c vpu_io.c -o vpu_io.o
make -C screenlayer all
make[2]: Entering directory `/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/imx-lib-1.1.0/pxp'
arm-cortexa9-linux-gnueabihf-gcc -DIMX6Q -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/drivers/mxc/security/rng/include -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/drivers/mxc/security/sahara2/include -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/include -Wall -O2 -fPIC -c pxp_lib.c -o pxp_lib.o
arm-cortexa9-linux-gnueabihf-gcc -DIMX6Q -Wall -O2 -fPIC -c vpu_util.c -o vpu_util.o
arm-cortexa9-linux-gnueabihf-gcc -DIMX6Q -Wall -O2 -fPIC -c vpu_lib.c -o vpu_lib.o
make[2]: Entering directory `/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/imx-lib-1.1.0/rng'
arm-cortexa9-linux-gnueabihf-gcc -g -Wall -W -Wmissing-prototypes -Wstrict-prototypes -Wdeclaration-after-statement -fPIC -DFSL_PLATFORM_OTHER -DFSL_HAVE_RNGC -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/drivers/mxc/security/rng/include -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/drivers/mxc/security/sahara2/include -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/include   -c -o fsl_shw_rand.o fsl_shw_rand.c
make[2]: Entering directory `/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/imx-lib-1.1.0/ipu'
arm-cortexa9-linux-gnueabihf-gcc -DIMX6Q -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/drivers/mxc/security/rng/include -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/drivers/mxc/security/sahara2/include -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/include -Wall -O2 -fPIC -c mxc_ipu_hl_lib_dummy.c -o mxc_ipu_hl_lib_dummy.o
arm-cortexa9-linux-gnueabihf-gcc -g -Wall -W -Wmissing-prototypes -Wstrict-prototypes -Wdeclaration-after-statement -fPIC -DFSL_PLATFORM_OTHER -DFSL_HAVE_RNGC -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/drivers/mxc/security/rng/include -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/drivers/mxc/security/sahara2/include -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/include   -c -o fsl_shw_hash.o fsl_shw_hash.c
make[2]: Entering directory `/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/imx-lib-1.1.0/sahara2'
make[2]: Leaving directory `/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/imx-lib-1.1.0/sahara2'
arm-cortexa9-linux-gnueabihf-gcc -DIMX6Q -Wall -O2 -fPIC -c vpu_gdi.c -o vpu_gdi.o
make[2]: Entering directory `/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/imx-lib-1.1.0/screenlayer'
arm-cortexa9-linux-gnueabihf-gcc -g -Wall -W -Wmissing-prototypes -Wstrict-prototypes -Wdeclaration-after-statement -fPIC -DFSL_PLATFORM_OTHER -DFSL_HAVE_RNGC -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/drivers/mxc/security/rng/include -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/drivers/mxc/security/sahara2/include -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/include   -c -o fsl_shw_sym.o fsl_shw_sym.c
arm-cortexa9-linux-gnueabihf-gcc -g -Wall -W -Wmissing-prototypes -Wstrict-prototypes -Wdeclaration-after-statement -fPIC -DFSL_PLATFORM_OTHER -DFSL_HAVE_RNGC -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/drivers/mxc/security/rng/include -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/drivers/mxc/security/sahara2/include -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/include   -c -o fsl_shw_user.o fsl_shw_user.c
arm-cortexa9-linux-gnueabihf-gcc -g -Wall -W -Wmissing-prototypes -Wstrict-prototypes -Wdeclaration-after-statement -fPIC -DFSL_PLATFORM_OTHER -DFSL_HAVE_RNGC -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/drivers/mxc/security/rng/include -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/drivers/mxc/security/sahara2/include -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/include -c ../sahara2/fsl_shw_keystore.c
arm-cortexa9-linux-gnueabihf-gcc -g -Wall -W -Wmissing-prototypes -Wstrict-prototypes -Wdeclaration-after-statement -fPIC -DFSL_PLATFORM_OTHER -DFSL_HAVE_RNGC -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/drivers/mxc/security/rng/include -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/drivers/mxc/security/sahara2/include -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/include   -c -o fsl_shw_auth.o fsl_shw_auth.c
arm-cortexa9-linux-gnueabihf-gcc -g -Wall -W -Wmissing-prototypes -Wstrict-prototypes -Wdeclaration-after-statement -fPIC -DFSL_PLATFORM_OTHER -DFSL_HAVE_RNGC -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/drivers/mxc/security/rng/include -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/drivers/mxc/security/sahara2/include -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/include   -c -o fsl_shw_hmac.o fsl_shw_hmac.c
arm-cortexa9-linux-gnueabihf-gcc -g -Wall -W -Wmissing-prototypes -Wstrict-prototypes -Wdeclaration-after-statement -fPIC -DFSL_PLATFORM_OTHER -DFSL_HAVE_RNGC -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/drivers/mxc/security/rng/include -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/drivers/mxc/security/sahara2/include -I/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/include   -c -o fsl_shw_wrap.o fsl_shw_wrap.c
make[2]: Leaving directory `/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/imx-lib-1.1.0/screenlayer'
vpu_io.c: In function 'IOPhyMemCheck':
vpu_io.c:596:16: warning: unused variable 'va_addr' [-Wunused-variable]
In file included from vpu_io.c:35:0:
vpu_io.c: At top level:
vpu_util.h:199:2: warning: 'EXIF_TAG' defined but not used [-Wunused-variable]
In file included from /home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/include/linux/pxp_dma.h:22:0,
                 from pxp_lib.h:19,
                 from pxp_lib.c:25:
/home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/include/linux/types.h:13:2: warning: #warning "Attempt to use kernel headers from user space, see http://kernelnewbies.org/KernelHeaders" [-Wcpp]
pxp_lib.c: In function 'pxp_get_phymem':
pxp_lib.c:141:2: warning: format '%x' expects argument of type 'unsigned int', but argument 4 has type 'dma_addr_t' [-Wformat]
In file included from vpu_gdi.c:15:0:
In file included from /home/bruno/BSP/BSP-Phytec-phyFLEX-i.MX6-PD12.0.3/platform-mx6/build-target/kernel-header-3.0.35/include/linux/videodev2.h:66:0,
                 from mxc_ipu_hl_lib_dummy.c:40:
vpu_util.c: In function 'SetParaSet':
vpu_util.c:791:11: warning: variable 'pDecInfo' set but not used [-Wunused-but-set-variable]
vpu_util.c: In function 'ParseJFIF':
vpu_util.c:2400:6: warning: unused variable 'pal' [-Wunused-variable]
In file included from vpu_util.c:20:0:
vpu_util.c: At top level:
arm-cortexa9-linux-gnueabihf-gcc -shared -nostartfiles -Wl,-soname,libipu.so.0 -o libipu.so.0 mxc_ipu_hl_lib_dummy.o -lpthread
vpu_lib.c: In function 'vpu_EncGetOutputInfo':
vpu_lib.c:1856:22: warning: variable 'address' set but not used [-Wunused-but-set-variable]
vpu_lib.c:1876:22: warning: variable 'address' set but not used [-Wunused-but-set-variable]
vpu_lib.c:1897:22: warning: variable 'address' set but not used [-Wunused-but-set-variable]
vpu_lib.c: In function 'vpu_EncGiveCommand':
vpu_lib.c:2114:8: warning: variable 'EncPicX' set but not used [-Wunused-but-set-variable]
vpu_lib.c: In function 'vpu_DecOpen':
vpu_lib.c:2437:15: warning: unused variable 'i' [-Wunused-variable]
vpu_lib.c: In function 'vpu_DecSetEscSeqInit':
vpu_lib.c:2712:11: warning: variable 'pDecInfo' set but not used [-Wunused-but-set-variable]
vpu_lib.c: In function 'vpu_DecUpdateBitstreamBuffer':
vpu_lib.c:3479:2: warning: format '%d' expects argument of type 'int', but argument 4 has type 'Uint32' [-Wformat]
vpu_lib.c: In function 'vpu_DecGetOutputInfo':
vpu_lib.c:4256:31: warning: variable 'address' set but not used [-Wunused-but-set-variable]
vpu_lib.c:4284:31: warning: variable 'address' set but not used [-Wunused-but-set-variable]
vpu_lib.c:4318:31: warning: variable 'address' set but not used [-Wunused-but-set-variable]
vpu_lib.c:4026:18: warning: variable 'paraBuffer' set but not used [-Wunused-but-set-variable]
vpu_lib.c: In function 'SaveGetEncodeHeader':
vpu_lib.c:4857:8: warning: variable 'n' set but not used [-Wunused-but-set-variable]
In file included from vpu_lib.c:26:0:
vpu_lib.c: At top level:
arm-cortexa9-linux-gnueabihf-gcc -shared -nostartfiles -Wl,-soname,libpxp.so.0 pxp_lib.o -o libpxp.so.0
arm-cortexa9-linux-gnueabihf-ar -rc libpxp.a  pxp_lib.o
../sahara2/fsl_shw_keystore.c:427:1: warning: no previous prototype for 'keystore_load_slot' [-Wmissing-prototypes]
arm-cortexa9-linux-gnueabihf-gcc -shared -nostartfiles -Wl,-soname,libfsl_shw.so.0 -o libfsl_shw.so.0 fsl_shw_rand.o fsl_shw_hash.o fsl_shw_sym.o fsl_shw_user.o fsl_shw_keystore.o fsl_shw_auth.o fsl_shw_hmac.o fsl_shw_wrap.o
arm-cortexa9-linux-gnueabihf-ar libfsl_shw.a fsl_shw_rand.o fsl_shw_hash.o fsl_shw_sym.o fsl_shw_user.o fsl_shw_keystore.o fsl_shw_auth.o fsl_shw_hmac.o fsl_shw_wrap.o
arm-cortexa9-linux-gnueabihf-ar: invalid option -- '_'
Usage: arm-cortexa9-linux-gnueabihf-ar [emulation options] [-]{dmpqrstx}[abcDfilMNoPsSTuvV] [member-name] [count] archive-file file...
       arm-cortexa9-linux-gnueabihf-ar -M [<mri-script]
commands:
  d            - delete file(s) from the archive
  m[ab]        - move file(s) in the archive
  p            - print file(s) found in the archive
  q[f]         - quick append file(s) to the archive
  r[ab][f][u]  - replace existing or insert new file(s) into the archive
  s            - act as ranlib
  t            - display contents of archive
  x[o]         - extract file(s) from the archive
command specific modifiers:
  [a]          - put file(s) after [member-name]
  [b]          - put file(s) before [member-name] (same as [i])
  [D]          - use zero for timestamps and uids/gids
  [N]          - use instance [count] of name
  [f]          - truncate inserted file names
  [P]          - use full path names when matching
  [o]          - preserve original dates
  [u]          - only replace files that are newer than current archive contents
generic modifiers:
  [c]          - do not warn if the library had to be created
  [s]          - create an archive index (cf. ranlib)
  [S]          - do not build a symbol table
  [T]          - make a thin archive
  [v]          - be verbose
  [V]          - display the version number
  @<file>      - read options from <file>
  --target=BFDNAME - specify the target object format as BFDNAME
emulation options:
  No emulation specific options
arm-cortexa9-linux-gnueabihf-ar: supported targets: elf32-littlearm elf32-bigarm elf32-little elf32-big srec symbolsrec verilog tekhex binary ihex
make[2]: *** [libfsl_shw.a] Error 1
2,686件の閲覧回数
brunoceldran
I found the solution to my problem :
There was a mistake into the Makefile (into the rng folder) concerning AR : the "-crv" arguments to the function were given into the first line :
AR = ar -crv
$(LIBNAME).a: $(OBJS)
    $(AR) $@ $^
and it was not working.
I replaced :
AR = ar
and
    $(AR) -crv $@ $^
And it's better.
