JLink with iMX25 ?
JLink with iMX25 ?
Don_ng
Has anyone successfully used the Segger JLink with the iMX25, using the Linux toolset from Segger ?  I'm trying to load a custom version of u-boot into RAM (and run it) to burn the fuses, so that we can use the ATK to program the FLASH.  I've had little to no luck in getting this working.  I've seen many people use OpenOCD with the JLink under Linux, but having never used OpenOCD, I'm hesitant to go down that road.
