Is it possible to reset the video subsystem
1,123 次查看
michaelworster
I have a product built on the i.MX6 DL. The display we're using connects via DVI to our board and makes use of the mxc_hdmi driver code. Occasionally the display gets into a state where it requires the display driver to be reset. A reset of the board works, but I'm trying to avoid a full reset. Is it possible to reset the display driver/video subsystem of just Linux/mxc_hdmi without having to reset the whole system?
Ideally I'd like some handle to change within Linux, but I'm willing to patch the kernel source if there's a good way this could be done from within the mxc_hdmi driver itself.
标签 (3)
1,051 次查看
fabio_estevam
Hi Michael,
Yes, it is possible to reset the eLCD controller.
Take a look at this commit I did for the mainline kernel:
https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/drivers/gpu/drm/mxsfb/mxsf...
You will need to adapt it to your kernel version though.
