If the clean Registry function (clean Register in the host PC) of Mfg tool was removed
640 次查看
StanleyLee
[Qustion}Could you confirm if the clean Registry function (clean Register in the host PC) of Mfg tool was removed or only run in background in the last releases of this tool.
[Answer] The function has been removed.
512 次查看
StanleyLee
Hi Abisai,
Yes, The reason is we set LUN to 0.
512 次查看
AbisaiNegrete
So, t he system of PC does not become unstable since registry does not increase. That is, the problem whose registry increases was solved. is this right?
