The IMX8MQ board we are using has a standard kernel version of 4.14.98. We have seen that the latest kernel version is 6.6.3,
We are porting a mipi driver for an IMX93 board (its kernel version is 6.1.55). If you want to use this mipi driver,
If we want to achieve dual screen display (such as the IMX8MQ chip with kernel 6.6.3), how do we want to upgrade the kernel version of the IMX8MQ chip?
Do you have a reference tutorial? What software, hardware, development environment, etc. are required to achieve version upgrades, and how long does it usually take?
Or perhaps the IMX8MQ board, with kernel version 4.14.98, how to fix it? What changes have been made to DRM? Where can I obtain them to achieve mipi driver and dual screen display functionality?
You can take the 6.6.3 kernel version and update your BSP from:
if you want to port it:
https://www.nxp.com/docs/en/user-guide/IMX_PORTING_GUIDE.pdf
regards
