IMX6 Qt5 camera
IMX6 Qt5 camera
1,928件の閲覧回数
vaudoitlaurent
Hi all,
on a custom board using imx6dp, with fsl bsp release, based on yocto warrior,
we are trying to get camera working with QT5.12.
camera are working well with nxp demo application mxc_v4l2_tvin.out
camera are working well with gstreamer command gst-launch-1.0 imxv4l2src ! imxv4l2sink
with imxqtplayer, i'm able to get the camera view (but not able to choose the device)
with qtmultimedia example declarative-camera, i'm not able to get it works.
my questions:
-is it correct that declarative-camera can not work as it does not use imx gst plugins?
-is there a way to get the imxqtcamera source code (in order to get our own test applications)? i've not been able to get it somewhere (seems we download a imxqtapplication binary)
thanks in advance for your help
Laurent
2 返答(返信)
1,889件の閲覧回数
vaudoitlaurent
thanks for your answer,
i'm able to use declarative-camera now, the problem was that i missed the settings of some env variable for CAMERABIN
export QT_GSTREAMER_CAMERABIN_VIDEOsrc=imxv4l2src
export QT_GSTREAMER_CAMERABIN_VIDEOSRC_DEVICE="/dev/video1"
Regarding the imxcamera application, is there a way to get the code? It seems this application use the overlaysink plugin, which does not do declarative-camera,
and we would like to be sure we use the better plugins for our applications.
Laurent
1,916件の閲覧回数
Bio_TICFSL
Hello vaudoitlaurent,
No, its not correct that declarative camera can not work with gst-plugin you should be able to use dev/VideoX to select your camera.
I suggest you to work whit 5.10.72 which have another version of yocto, to avoid those problems with qt and your camera. you can download it from:
https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat...
