How to display a rtsp streaming
2,472 次查看
weideding
I am using I.MX8M EVB, Yocto wayband QT5, trying to display a rtsp streaming over HDMI. I tried gst-player,  gtk-play, gstreamer as below command lines, all did not work. And  VLC2.2.2 built in yocto QT5 does not work also, no any window interface appear.  Which way can make it work?  Thanks.
gst-launch-1.0 rtspsrc location=rtsp://<SERVER_IP>:8554/test name=source ! queue ! rtph264depay ! h264parse ! imxvpudec ! imxipuvideosink
gst-launch-1.0 rtspsrc location=rtsp://<SERVER_IP>:8554/test ! queue ! rtpjitterbuffer latency=100 ! rtph264depay ! avdec_h264 ! autovideosink sync=false
标记 (1)
1 回复
1,902 次查看
jimmychan
