Hi makoto
it is not possible to disable and then reinitialize wdog
as some bits (like WDE- enable) are once write. Regarding connection
WDOG-output-signal to POR-input-signal, one can try solution used
on i.MX6 SabreSD schematic spf-27392 p.21 with U507 buffer.
Other solution may be reinit wdog signal as gpio using pin multiplexing
with IOMUX registers.
