How to deal with rare fec MDIO read timeout?
2,610件の閲覧回数
changbaoma
i can reproduce in my custom im6ull+PHY-LAN8720 board after hundreds of times of cmd "ifconfig eth0 down" then "ifconfig eth0 up" , looks like:
any advise?
5 返答(返信)
2,543件の閲覧回数
changbaoma
I solved this issue by disable LAN8720's Energy Detect Power Down (EDPD) mode. Thank you all.
2,604件の閲覧回数
igorpadykov
Hi changbaoma
one can look at suggestions provided on
https://www.spinics.net/lists/netdev/msg429838.html
and try latest nxp linux releases:
https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat...
2,594件の閲覧回数
changbaoma
Thank you @igorpadykov
       i have try  two ways, but do not make any difference.
       1)  remove clk_ipg disable at runtime.
 --- a/drivers/net/ethernet/freescale/fec_main.c
+++ b/drivers/net/ethernet/freescale/fec_main.c
@@ -4141,7 +4141,7 @@ static int __maybe_unused fec_runtime_suspend(struct device *dev)
struct fec_enet_private *fep = netdev_priv(ndev);
clk_disable_unprepare(fep->clk_ahb);
- clk_disable_unprepare(fep->clk_ipg);
+ //clk_disable_unprepare(fep->clk_ipg);
release_bus_freq(BUS_FREQ_HIGH);
       2) slow down smi clk (mdc) from 2.5MHz to 1.5MHz
i don't try the latest nxp linux releases, because my custom board not compliant fully with NXP demo board.
Any ideas?
2,590件の閲覧回数
igorpadykov
one can try to debug it using AN4553 Using Open Source Debugging Tools for Linux on i.MX Processors
https://www.nxp.com/docs/en/application-note/AN4553.pdf
2,563件の閲覧回数
changbaoma
the mdio timeout is came from imx6 fec controller , do you think this debug document fit for my issue?would you show me your steps?
