How can I read OCOTP of I.MX28 ?
972 次查看
prab
   What  programmer should  I use?   SmartPro5000U (http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=i.MX287&nodeId=018rH3ZrDRA24A&fpsp=1&...)  does not support  I.MX28
4 回复数
814 次查看
YixingKong
Senior Contributor IV
Pranas, could you move this dicussion out of your own space to i.MX Community so that others could see and provide answers.
Yixing
814 次查看
prab
Dear Yixing,
I dont know what it meant to move discussion and how it can be done.
Pranas Banys
Inžinierius-konstruktorius
Tel. +370 613 25073
UAB Tomahawk Diagnostic Technologies
Jasinskio 17, Vilnius, LT-01111, Lithuania
814 次查看
YixingKong
Pranas, Freescale community consists of two types of spaces--- public and private space. When you post your discussion in public space everyone will see your discussion and can answer it. The discussion is in your private space and others would not see it unless you pass link to someone. In order to move your discussion into public space you can click move on right-hand side menu list after login and search i.MX Community. Once you successfully move a discussion, i.MX Community will show up on the top left of your screen.
Yixing
814 次查看
GraceH
Senior Contributor II
IMX_OTP_TOOLS : A set of tools for managing OTP bits on the i.MX23 and i.MX28. Contains BitBurner.exe, the otp_burner.py and BitInit.exe. Update fixes a problem where incorrect values were sometimes burned into the OTP fuse register.
Size (K): 3973 Format: zip Rev #: 1.3.3 Modified: 4/11/2013
Grace
