HOW TO REMOVE RED BOX APPEARED AT IMX6 SCREEN BOARDER
1,069 次查看
chandrasekharma
Hi all
I am getting one problem in freescale imx6 sabresd board. While bootup time, opening camera, capturing image, and opening recent apps etc... I am getting one red rectangular box on screen boarder
So my exact question is "how this redbox is coming because of what reason?"
Will anyone please explain clearly this discussion?
For your reference i attached one screen shot please find this..
Thanks in advance
标签 (4)
837 次查看
gary_bisson
Senior Contributor III
Those red frames are for debug purposes, it means that the main thread of the running application is taking too long.
In order to remove those frames, you can either build a new image in user mode instead of engineering.
Or another (simpler) solution is to set those properties;
$ setprop persist.sys.strictmode.visual=0
$ setprop persist.sys.strictmode.disable=1
Hope this helps. If it resolves your issue, please mark it as correct answer and close the thread.
Gary
838 次查看
gary_bisson
Gary
837 次查看
SergioSolis
Thank you for your help Gary!
837 次查看
chandrasekharma
Thank you Gary Bisson..So helpful at correct time
