Format conversion for YUV444 to YUV422 of IMX6Solo.
takashitakahash
Dear community.
Our customer has question below.
Customer has able to capture analog video at iMX6 solo,
However,video capture supported by the YUV444 only  but I require YUV422 format.
I am Format  conversion is necessary but i could not be found .
Would you please  provide information for YUV444 → YUV422 conversion library .
Thanks Best.
joanxie
mx6S has IPU which has CSC module to change color space conversion by hardware, for more detailed inforamtion, pls refer to the chapter 38.4.9.5 Color Space Conversion unit - CSC
<http://cache.nxp.com/files/32bit/doc/ref_manual/IMX6SDLRM.pdf?fpsp=1&WT_TYPE=Reference Manuals&WT_VENDOR=FREESCALE&WT_FILE_FORMAT=pdf&WT_ASSET=Documentation&fileExt=.pdf>.
