I am using the SDMMC sd card fatfs SDK example code in IMXRT1050EVKB , i am able to write and read the content into the file. Code is absolutely working fine.
My doubt is,
if i want to copy the content of one file and write the content into another file , we cant copy a whole file content into a buffer then write it, as size of file is around 2mb and its not possible to keep a huge buffer size
is there any other possibility to copy and paste the content of file as f_copy is not supportive?
Please do the needful.
You can write a C code to copy fine with small blocks, even byte by byte.
