Building the u-boot bootloader from 10.0.0_2.3.0 is now failing
injaneer
I have downloaded t he 10.0.0_2.3.0 Android build for the imx8mm Mini, and went through all the steps to setup the environment and project tree. I was able to build the bootloader, kernel, and rest of system the first time through.
I Had made a couple of changes to swap out for a different PMIC (PCA9450), and tried to recompile the bootloader and now I get this error messages (attached).
Since I first thought maybe something I had changed, I reverted my changes and tried to build again same thing.
So after trying many other things I came to desperation and completely removed the android_build folder and re-synced to the repo.  Now on this fresh install, I get the same attached errros.
injaneer
Thanks, I have solved this.  The make command does not like the undefine in the makefile. I just removed it.
injaneer
I know this is an error with one of the many make files, but I got this message after removing the android_build folder and the /bin/repo and re-syncing to the project. Can someone please check the build tree to see if there an issue with it.
AldoG
I'll try to build it on my side, I'll let you know of my results, meanwhile I would like to ask what changes have you made to source code?
Aldo.
injaneer
AldoG
Glad to hear it is now working properly.
Aldo.
injaneer
forgot attachement.
