Build and launch xen with imx-5.4.70 on imx8qxpc0mek
swapna
need your support in launching xen on imx8 board(imx8qxpc0mek)
below is teh build procedure followed
repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-zeus -m imx-5.4.70-2.3.0.xml
repo sync
MACHINE=imx8qxpc0mek DISTRO=fsl-imx-wayland source ./imx-setup-release.sh -b imx_build
bitbake xen
we are running this on ubuntu 20.04
after build is completed, in images folder i could not see rootfs.wic.bz2 at all
Strangely all are .dtb files
Need your support in launching xen
@Bio_TICFSL
swapna
@Bio_TICFSL
Thank You for the reply.
i built more than 5 times. but my question is is the procedure mentioned above right?
am i missing something?
Bio_TICFSL
Hello Swapna,
Complete filesystem images are deployed to <build directory>/tmp/deploy/images is not there then you need to build again.
