Boot time of Android 13.4.1 on the sabre board i.mx6
1,547 次查看
marcoc
Hello to all,
I need to have the timestamp of the boot up  of Android on my i.mx6 but in minicom I could not d it.
Have you any idea for solve this problem?
Marco
标签 (2)
8 回复数
1,335 次查看
leige-b42127
Senior Contributor II
make menuconfig
Kernel hacking -> Show timing information on printks
1,335 次查看
marcoc
This is already enabled.
Thanks Marco
1,335 次查看
LeonardoSandova
Specialist I
Not sure how this is done in Android but I assume it should be as in Linux, adding the CONFIG_PRINTK_TIME=y configuration. There is also a host app which timestamps every line coming into the serial, it is called grabserial.
Leo
1,335 次查看
marcoc
I tried to install grabserial but doesn't work. I have two errors in the first two lines of code, I think there is a problem with <!DOCTIME html> but I dont know which could it be.
Do you know how to solve this problem?
Thanks Marco
1,335 次查看
LeonardoSandova
Specialist I
Hi Marco, create a new thread for this particular problem, so the title is more specific. weren't printk's timestamps enough information? or you need to have also timestamps on bootloader?
Leo
1,335 次查看
marcoc
Hi Leo, I don't have any timestamps because minicom doesn't have, and I need also the timestamps on the boot loader.
Marco
1,335 次查看
Rita_Wang
Hi Marco,
Which board are you using?
Best Regards
Dan
1,335 次查看
marcoc
A sabre board i.mx6 quad core.
Marco
