About JTAG connection when a data abort occurred in i.MX7
1,229件の閲覧回数
yuuki
Senior Contributor II
Dear all,
We perform system development using i.MX7.
We debug it using IAR J-Link.
When exceptions such as Data Abort occur, we cannot look at any registers of ARM from J-Link.
We seem that it cannot access the CPU.
Such a problem does not occur with other companies's CPU.
We suspect that there may be some problem with JTAG I/F of i.MX7.
Is there the method to get information definitely from J-TAG when an exception occurs in i.Mx7?
May I have advice?
Yuuki
ラベル(2)
1,081件の閲覧回数
sinanakman
Senior Contributor III
Hi Yuuki
Regarding to what you mention in your mssage :
"We suspect that there may be some problem with JTAG I/F of i.MX7."
I have another jtag probe here (BDI3000). I wonder if it helps
you if I try this out with another probe to isolate the issue to CPU.
If you think this is any help, please send me your complete
procedure that I can repeat here when I have some time.
Hope this helps
Sinan Akman
