there is no USE driver when use qn908 DK board
wdliming
There is no USE driver when i use qn908DK board, so  i can not use usart example.
Is there any solution to solve it? thank you!
estephania_mart
In which connector are you plugging your board? COuld you please try updating the drivers in the device manager ?
wdliming
i use in usb no j2, but i failed to update the driver when  try updating the drivers in the device manager...
estephania_mart
Could you please try to install the drivers for the CMSIS-DAP debugger and virtual COM from the LPCScrypt utility?
Estephania
wdliming
it is a pity, after intalling the LPCScrypt Windows Installer v2.0.0(REV 2.0.0), the IAR workbench can not download the hex file..
as you know, i use the QN908x dk, is that the LPCScrypt Windows Installer v2.0.0(REV 2.0.0) suitable for qn908xdk?
estephania_mart
Yes, please remember that the board has an LPC that takes care of the USB-to-serial kind of translation, so the missing driver might be the LPC instead of the QN9080 one.
wdliming
let me try,
thank for your suggestion!
