require hostapd.conf&wpa_supplicant.conf for W8997 sdio wifi Throughput test
changbaoma
i get a document named《SD-WLAN-SD-BT-8997-U16-MMC-W16.68.10.p162-16.26.10.p162-C4X16693_V4-MGPL》from NXP Distributor.
This doc list results of Throughput Test under different AP/STA modes, like
80211.BGNMode-2.4GHz-Band20/40MHz,
80211.ANMode-5GHz-Band20/40MHz, and
80211.ACMode-5GHz-Band20/40/80MHz.
In fact, our test result is much smaller than the value given by doc tables on imx6ull. I also suspect that there may be something wrong with my configuration file hostapd.conf & wpa_supplicant.conf .
So, Wireless support team, can you provide us the hostapd.confs according to the each Throughput Test mode above.
