When installing "ZB pro configuration edition 2.0.0" for "JN-SW-4141 BeyondStudio for NXP v1308", an error message appears: "Cannot complete the install because one or more required items could not be found. Software being installed: NXP ZBPro Configuration Editor 2.0.0 (com.jennic.sdk.zbpro.external.feature.feature.group 2.0.0) Missing requirement: ZBPro Config Edit Support 2.0.0 (com.jennic.zps.configeditor.edit 2.0.0) requires 'bundle org.eclipse.emf.edit 0.0.0' but it could not be found. Cannot satisfy dependency: From: NXP ZBPro Configuration Editor 2.0.0 (com.jennic.sdk.zbpro.external.feature.feature.group 2.0.0) To: com.jennic.zps.configeditor.edit [2.0.0]".
I followed the instructions in "JN-UG-3098 BeyondStudio for NXP Installation and User Guide" exactly and have tried on different systems and PCs, but the problem remains unsolved.
Hi @why3303 ,
Thank you for contact NXP support. I apologize for the late response.
I reproduced your problem on my side and the same result appeared. It is now being communicated internally to more experienced colleagues in this field.
Also, there have been similar posts and solutions in NXP Community, can you refer and try this first?
problem install plugin ZB pro configuration editor
B.R.
Gavin
I also saw this post and tried the solutions inside, but they didn't work. I hope this issue can be resolved soon. Thank you for your response.
Hi @why3303 ,
Sorry for the late reply.
Hope you are doing well.
Because this IDE is very old, my colleagues and I spent a lot of time looking for a solution.
Please try the following in order to install the plugin:
Note : PLEASE DO NOT SELECT "EMF Core and MDT XSD", this operation is only to trigger the IDE to have its update site available to search for dependencies.
Installation may take a while, please wait until it is finished.
B.R.
Gavin
