i'm using the i.MX RT 1060 SDK along with the iw416, and when I load the evkmimxrt1060_wifi_webconfig example, with:
yes. this particular module has a built in trace antenna.
I´m sorry for the late reply.
Could you please take a look to AN12918 available in the following route of your SDK bundle?
C:/…/SDK_2_12_0_EVK-MIMXRT1060\docs\wireless\Wi-Fi
There might be some Tx power configuration missing and this document might help you.
I hope this helps.
Best regards, Daniel.
Just to confirm, did you connect the respective antenna for the Wi-Fi Tx/Rx in the AW-AM457-uSD module?
