I use i.MX RT1060 Evaluation Kit plug AW-AM510uSD to connect wifi.
When I use evkmimxrt1060_wifi_cli from sdk to build and debug was no problem, but type "help" at terminal only show 3 commands can be used.
So I cannot use the command like "ping" and so on, can anyone share me some advices?
Solved! Go to Solution.
Sor, I didn't mention that I used rt1060 evkb, and then based on Technician's advice, SDK should use another(https://mcuxpresso.nxp.com/en/builder?hw=MIMXRT1060-EVKB).
Besides, I changed VIO on AM510.
Now, it works perfectly!
