There are figures for TRP/TIS test results in this document.
For example, the TIS figure is shown as -87,06.
What do -87 and 06 mean, respectively?
Do you mean 87.06?
It is difficult to understand the table because there is no supplementary explanation for the result value.
Hello @swhyun
Hope you are doing well.
Just to confirm, what is the device you are using?
The comma (,) may act as a decimal separator. You can consider the value inside each box as a single decimal value (i.e., 87.06).
Eduardo.
