Selection of MCU for WiFi + Bluetooth Adapter Design
MartinEnG
I'm trying to design a WiFi + Bluetooth adapter module for an EVSE. I was planning to use an RF MCU SoC from your product line for this application. I wanted to use one of the following ranges: RW612, RW610, or 88MW320/322, but it's almost impossible to get any of these chips. I primarily purchase my products from Mouser, and they don't have stock of any of the mentioned SoCs. So, I have to consider other MCUs. Could you recommend an MCU with WiFi + Bluetooth that I can use for my application and is compatible with MCU-Link?
Walter.
DanielRuvalcaba
The only options of “Wireless Hostless MCUs” are RW61X and 88MW32X.
You can use another MCU like the ones in the i.MX RT family, but you will need to get a wireless module (which already includes a NXP Wi-Fi chipset) in order to use Wi-Fi/BT.
Please take a look to UM11441 to see the supported combinations of wireless modules and RT MCUs.
In case it helps, we have a solution called EasyEVSE EV Charging Station Development Platform in case you’d like to take a look.
I hope this helps,
Daniel.
