SLN-TLHMI-IOT WiFi Solution Example For The Azure RTOS
Wobaffet
Senior Contributor I
For our custom board, we plan to utilize the same WiFi module found on the SLN-TLHMI-IOT board, which is paired with the RT1176 MCU. While there are existing example implementations based on FreeRTOS for this module, we are specifically interested in determining if there are any available example implementations compatible with Azure RTOS.
Labels (3)
nxf77486
Thank you in advance for contacting NXP support.
There is not an specific example of the SLN-TLHMI-IOT with AzureRTOS. But you can find an example of usage of this on the getting started below. The SLN-TLHMI-IOT has an IW416 module and we have an example of the Wi-Fi integration of this module with Azure RTOS I also include the link to this guide below. Please let me know if there is anything else where I can help you.
Getting Started with the SLN-TLHMI-IOT
https://www.nxp.com/document/guide/getting-started-with-the-sln-tlhmi-iot:GS-SLN-TLHMI-IOT
Wi-Fi Integration
https://www.nxp.com/design/training/ev-charging-wi-fi-integration:TIP-EV-CHARG-WI-FI-INTEGR
nxf77486
Wi-Fi Integration
