Ntag 5 configuration with CLEV6630B and Ntag5 NFC cockpit
amin_bcs22
I am using  Ntag5 NFC cockpit to configure my ntp5332 (OM2NTP5332) through CLEV6630B board. after some working without any problem the configuration registers ( 3Eh,...) has been out of access and cant be configured that is followed by " Read configuration block 3Eh error" reporting . in addition the related blocks in memory view has been hidden. please give me some advices as it possible.
KellyLi
Hello amin_bcs22,
The configuration memory contains the security and configuration information. Different perspective (NFC/I2C) accessible areas are somewhat different, you can check table 11 on page 15 of the data sheet, and for details please refer to the data sheet.
Thanks&Best regards,
Kelly
KellyLi
Hello amin_bcs22
Could you share me Screenshot of your test configuration and result, and then I'll try to reproduce your issue on my side.
Kelly
amin_bcs22
Hi Kelly,
Thank you so much for your kindly reply. I have found the problem. I had set the SRAM_CONF_PROT all fields. so my access to all configuration registers (37h to 45h) has been terminated. I tried to do factory reset but it got failed.
there is an question, if I can bring them in access or not(maybe it got set permanently)?
Amin
KellyLi
Hello amin_bcs22,
Kelly
