NTAG I2C Configuration register settings
preethimh
I'm using NTAG I2C chip NT3H2111 for one of my projects, i would like to enable the NFC SILENCE Feature. So, i changed the configuration register at 0X3A to 0X81 which enabled the feature and the tag wasn't visible to any reader. But, when I tried to write it back to 0X01 I'm unable to get the tag back to Tag being visible to the reader.
is there any procedure that should be followed to set the configuration registers?
or is the Configuration registers only one time programmable?
