Hello.
I am testing Generic FSK example on MKW41Z EVM.
The datasheet shows that sensitivity can be improved at 250Kbps data rates.
So I changed radio configuration parameters like a below because for sensitivity improvement but wireless communication does not work.
Default:
static GENFSK_radio_config_t radioConfig =
.radioMode = gGenfskGfskBt0p5h0p5,
.dataRate = gGenfskDR1Mbps
My setting:
.dataRate = gGenfskDR250Kbps
What else do I need to change to use 250Kbps?
Thank you.
Hope you are doing well. Could you please describe how are you testing it? What do you mean with "wireless" communication does not work?
What SDK version are you using? Was that the only modification you made to the example?
Ricardo
