MKW21Z Configure GPIO For Open Drain
898 次查看
unknowncoder
I am trying to figure out how to configure the GPIOs in open drain mode. I have read the reference manual but I don't see any bits that control this.
I need to configure an output PIN in open drain mode so that if other output pins pull the line low it does not affect the bus.
So I need to configure the PIN in output opendrain
793 次查看
estephania_mart
Sorry for the inconvenience this might cause you, but the KW21Z does not have open drain control as you can check in the reference manual
Estephania
