JN5189 profile and endpoint
Viki
Hi All,
The chip I use is JN5189 and the SDK version I use is SDK2.6.2_JN5189DK6.
Profile ID is currently configured using the ZPFCFG file. Profile ID information is contained in the s_sApl structure.
How to dynamically modify Profile ID and Endpoint?For example, profile ID ,endpoint and clusterID are configured via UART commands.
Thank you for your reply!
mario_castaneda
Hi @Viki,
I hope you are doing great.
Unfortunately, we do not provide an example that help you to add or edit the endpoint or clusters dynamically. Please look at the JN-AN-1247 The IoT Control Bridge supports Zigbee Lighting & Occupancy (ZLO) devices, controlling the network by mostly client cluster commands.
In other words, the device is waiting for the host UART commands.
Hope it helps.
Mario
