JN516x-EK004 Kit's Node fails to join IoT gateway through NFC
zgmwork
Hi,After my JN516x-EK004 Kit's general extension node downloaded the "DimmerSwitch" program "JN-AN-1219-Zigbee-3-0-Controller-and-Switch-v1007", it always failed to join the supporting IoT gateway through NFC, and the buzzer rang four times in a row. The "decommission device/commission device" of the login iot-gw.nxp web operation cannot be added. But the node suite before downloading this program can be added through NFC. Is this new program not matching, or something else?
mario_castaneda
Hi Guomiao,
Are you using the JN-AN-1216? Did you look at the 1.4 Network Commissioning JN516x-EK004 Evaluation Kit User Guide?
Could you please provide more details about your issue?
Mario
