How to cancel a scheduled by PWRM_eScheduleActivity() event
Alkarax
Hi! I am developing a zigbee sleeping device using jn5169 MCU and JN-SW-4170 SDK. When the device loses its connection, it should go to sleep and wake up once a minute and try to reconnect, but if the button is pressed, it should also wake up and try to reconnect. I am using the PWRM_eScheduleActivity () function to sleep. How to cancel or restart an event scheduled by this function if the button was pressed and the reconnection was successful?
Tags (2)
mario_castaneda
Hi Alkarax,
Could you please confirm the AN that you are working on?
What is the value that you are getting in the variable u8WakeInt in the vISR_SystemController function?
What is the timer that you are working on?
Mario
mario_castaneda
Hi Alkarax,
I am sorry, I think that I am understanding your issue.
Are you still getting the button event after the reconnection?
Mario
Alkarax
Yes, I do.
mario_castaneda
Hi @Alkarax,
Just to confirm, do you want to avoid entering into sleep mode after the reconnection?
You could call PWRM_eStartActivity to avoid entering into sleep mode and after that, you could call PWRM_eFinishActivity to allow entry into sleep.
Mario
Alkarax
Hi, Mario! No, not like this. Imagine the situation: my device lost connection and enter into sleep for a minute, after 10 seconds I press a button, and it wakes up and reconnects successfully. Now I need to enter into sleep and wake up every 5 seconds (because I am online and send pull requests), but a minute from the beginning of the first sleep has not passed and the past event is still active, even though I no longer need it.
