For audio applications, we plan to connect the AW-CM276MA-PUR(NXP 888W8997) WIFI/BT combo chip to the imx8qxp EVK.
Does the imx8qxp M2 connector support the PCM interface mentioned in the AW-CM276MA-PUR datasheet?
If so, explain the use cases of the PCM interface.
Thank you in advance for contacting NXP support.
Regarding yur question please find the Azure Wave Datasheet for the AW-CM276MA-PUR product in the section 3.4.3 PCM Interface, you would be able to see in more details the PCM interface.
Please let me know if there is anything else where I can help you.
