88W8997 easyMesh
88W8997 easyMesh
frank-TC
hi I'm frank. I am testing on Linux OS using SPB228 (purchased from hd wireless) module based on Marvell 88W8997. I tried to implement WIFI MESH, but the driver for easyMesh was not provided, so I was looking for other products. Then I found DVK-ST60-2230C Evaluation kit made based on 88W8997 states that it supports easy mesh. Can I get the Linux os driver for the kit? where? Also, is it possible to apply that driver to spb228?
estephania_mart
Could you please help us contacting the module manufacturer for some more information about the available resources for the module ?
The device indeed supports Mesh, still, you will need to check with the module manufacturer to validate the available drivers and enablement available for the specific module
Estephania
frank-TC
Thank you,
The URL where the product was purchased is https://www.hd-wireless.com/
I purchased the SPB228 Evaluation board(HDA228-USB-SDIO) module here, and brief information about the product is http://docker.hd-wireless.com/Support/SPB228
If you don't log in, you can only see very limited information.
Pls, ask you to confirm about supporting Mesh..
estephania_mart
Hello ,
Yes, I understand, that is the reason why I mentioned the chip supports that but you will need to verify with the manufacturer of your module about the enablement of those capabilities within their drivers.
Estephania
