Hi NXP
I want to test two audio sources at the same time.
Are dual source profiles supported at the same time?
I would like to know how to test if possible.
Thank you
Solved! Go to Solution.
Hello @Simonum ,
See below, please!
No, it doesn't.
Only 1 A2DP channel is supported.
weidong
Dear @Simonum ,
>.What is the normal audio delay time when using A2DP profile and SBC codec?
Maybe 200ms?
It's hard to say how much time is normal for the delay. Because it is also related to platform. But 200ms is not long.
I have ever configured 1 channel A2DP sink on i.MX8MN-EVK + 88w8987 BT, mobile plays music , and listen to it on i.MX8MN-EVK side. at the time, i.MX8MN-EVK + 88w8987 board is just like a "Big BT headset" .
weidong
Hello weidong
Thanks for your help.
