88W8801-SDS front end design and alternatives
jupiter_hce
Due to lack of technical support about my WiFi firmware issues described at https://community.nxp.com/t5/Wireless-Connectivity/SD8801-firmware-disconnect-issue/m-p/1389108#M125... I am looking for an alternative option to redesign the PCB using 88W8801-SDS, here are my questions:
(1) How stable is the 88W8801-SDS and firmware mrvl/sd8801_uapsta.bin?
(2) Any technical supports if I have troubles?
(3) I looked at datasheet, it needs to add RF Front End Interface baseband filters, our hardware engineer is not good to it, can we get your application engineer support ? Or do you have a completed front end WiFi module product to integrated the the RF baseband, crystal and shielding CAN?
Thank you.
Kind regards,
jh
weidong_sun
Hello @jupiter_hce
Hello @jupiter_hce ,
New driver for 88W8801 has been sent to distributor FAE Sumit Malhotra,
you can try the driver.
Have a good day!
weidong
