#fxas21002c #IIO
Hi All,
Are my below calibration values correct?
1. Referring to Page 40 of FXAS21002C datasheet,
#define FS_AVL_2000_GAIN 1090
#define FS_AVL_1000_GAIN 545
#define FS_AVL_500_GAIN 272
#define FS_AVL_250_GAIN 136
1090 is degrees to radians convertion of 62500. I'm using this value as senstivity mentioned is 62.5 mdps/LSB.
static IIO_CONST_ATTR(in_gyro_scale_available, "0.001090 0.000545 0.000272 0.000136"); ---> These are macro values of above #defines
static struct attribute *fxas2100x_attributes[] = {
&iio_const_attr_sampling_frequency_available.dev_attr.attr,
&iio_const_attr_in_gyro_scale_available.dev_attr.attr,
NULL,
2. I'm using Android 6.1 Marshmallow and below hrec file. I chose some values based on my understanding from datasheet, remaining I copied from a different gyro hrec. Are the chosen values correct? Please suggest correct values.
ro. iio.anglvel.max_range=30 -------------------------------> copied from a different part.
ro. iio.anglvel.resolution=0.001 -----------------------------> This value I took from sensitivity as it is mentioned to be mdps/LSB
ro. iio.anglvel.power=3 ------------> Copied from different gyro
ro. iio.anglvel.scale=0.000545 -----> Micro value of the gain that I'm using
ro. iio.anglvel.quirks=hrtimer noisy biased
ro. iio.anglvel.max_freq=100 ---------------> copied from a different gyro
Gangadhar
