unable to flash the s32k146 using Trace32.
vinay_kushwah
I am unable to flash the S32K146 using Trace 32. While flashing I am getting Target reset detected. Also while debugging I found that it is stopped at "FLASH.Reprogram 2. /ERASE".
I tried FLASH.Erase ALL and FLASH.Program ALL too but both are not working. I am getting error target reset while flashing or erasing. Do you know, How can I recover the board, something like master reset!!
Thanks in advance
rweiss
Contributor V
Please try with the original flash script provided by Lauterbach. You will find it in your TRACE32 installation directory under demo\arm\flash\s32k.cmm
