s32k344 some memory denied access
huangjia
Hi dears, i'm debugging s32k344 via jlink. I generated a project to toggle a led pin, and it can work fine. But i can not read the pin register via memory. How to set memory access range?
Senlent
Hi@huangjia
I can accsee the address as you did,for example:0x40290000,
       I am currently using PE(I don't have a segger jink) ,so i think this may be caused by J-LINK ,may be you can try with onboard PE to trobleshoot this problem.
BR!
     Jim,
dashe
Hello, I want to ask whether you use j-link V10 or V11?
huangjia
no,I switched to pemicro
dashe
I saw that you said you used j-link first. I want to ask which model you used to use j-link
Senlent
Hi@huangjia
BR!
     Jim,
huangjia
Yes, i configured over this factor, and shopped one on line. I plan to try when receiving it.
Senlent
Hi@huangjia
      okay,welcome to discuss with you.
      Are you use S32K3X4EVB or self-design board? S32K3X4EVB have an on-board debugger(can easily connect to PC by usb-wire)
BR!
     Jim,
huangjia
That is my self-design board. It is hard to apply a demo board now.
Senlent
Hi@huangjia
       I got it!
       Can I close this question? If you have other questions, you can post a new question in this forum.
BR!
      Jim,
