how to connect S32k146 with NXP_RGB1_Shield Rev. 1.2
aakash_kumar78
please tell me, how do i make connection between S32k146 and NXP_RGB1_Shield Rev. 1.2.
please provide me any data pdf for NXP_RGB1_Shield Rev. 1.2, so I will understand.
Julián_AragónM
Hi @aakash_kumar78,
Could you elaborate on which device the "NXP RGB1 Shield" you are talking about?
Are you referring to the S32K-ISELED LED Lighting Solution? If so, you can find the User Guide, Getting started guide and reference manual under "Documentation" from the product page.
Julián
aakash_kumar78
I have one AMS OSRAM (NXP_RGB1_sheild Rev. 1.2 Bidir_Loop) and one NXP s32k146 EVB. For Your reference one Image is attached.
Q 1. is any document available for this RGB1_sheild? if yes so, where I found the document related to RGB1_sheild?
Q 2. is having any library available for drive this RGB_sheild?
Julián_AragónM
Hi @aakash_kumar78,
Unfortunately, I could not find any information about the NXP RGB1 Shield device, please help me contacting the distributor/contact where you got the shield from?
Julián
