encryption for data in SPI flash
ソリューションへジャンプ
3,354件の閲覧回数
sai-bodhanapu
hello, i am using s32k312 mcu with AUTOSAR drivers from latest RTD. i can see there are crypto drivers. can i use these drivers for encrypting my spi flash data?
please let me know.
Thanking you in advance.
3,324件の閲覧回数
lukaszadrapa
Hi @sai-bodhanapu
Yes, the crypto drivers can be used to encrypt data in SPI memory. See the examples in the RTD package.
Notice that HSE firmware needs to be installed first. This is up to user, this is not programmed in the factory.
We provide document AN744810 “HSE FW install for S32K3xx” which describes how to install the firmware. It can be found in Documentation in Secure Files section:
https://www.nxp.com/products/processors-and-microcontrollers/s32-automotive-platform/s32k-auto-gener...
Then we provide HSE FW and HSE DEMOAPP as a part of S32K3 Standard Software package:
https://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=SW32K3-STDSW-D
HSE DEMOAPP contains a number of scripts for Trace32 which shows how to do all the install – update – program operations. Document HSE_DEMOAPP_..._ReadMe.pdf explains how to use the scripts. The scripts can be modified per your needs.
Lukas
2 返答(返信)
3,322件の閲覧回数
sai-bodhanapu
thank you @lukaszadrapa, i will look into it
3,325件の閲覧回数
lukaszadrapa
Hi @sai-bodhanapu
Lukas
