The hardware settings required for project 'FLCM_4CH_S102' not found.
GAC-Lamp-Knight
Dear NXP Engineer,
I have installed S32DS for ARM V2.2 (Windows), and now when I compile the project, I see a warning message in the Problems panel:
Description Resource Path Location Type The hardware settings required for project 'FLCM_4CH_S102' not found. FLCM_4CH_S102 FLCM_4CH_S102 S32 Project Version Problem
Could you please tell me what the problem might be, how I can fix it, and what potential project risks there might be?
Tags (2)
Senlent
GAC-Lamp-Knight
Senlent
Hi@GAC-Lamp-Knight
“'FLCM_4CH_S102”该工程你是导入至你的IDE中的还是直接复制到你工程目录下的?
请使用导入(import project)然后再测试下是否还有该问题。
如果不行,我需要你提供下工程,可以私发给我。
Senlent
